Error code on heat
Question
Turned on heat in my 2002 43 open yesterday-came on in both salon and bedroom.  Control panel in salon after 10-15 minutes started flashing what looks like three backwards g or 9.  Restarted it and happened again.  No luck finding that code on line...any of you guys know what that code is?
Thanks!
Assume you have Marine Air units with Passport II controls as that is what I have on my 2003 38 Open. If that is true the display maybe the letter "P".. ("PPP"). If it is then the unit has detected " low freon pressure. Compressor will not start until fault is cleared".. I.ve attached the manual for the Passport II Controls. Check page 20 to see if this helps....
  HPF error and strainer location d5dekeyser 1 1,606 05-03-2024, 09:02 PM
  AC Code "HHH" hookup44 9 9,821 09-29-2018, 11:40 AM
Last Post: hookup44
