Threads: 8
Home Port: Palm harbor, Fl.
I am considering the purchase of a '96 31 open with Crusaders but have concerns with being able to access to the engines but particularly the sea strainers. Both are located aft of the engines and somewhat below the exhaust hoses. This does not look like an ideal place for these considering that they should be frequently inspected and cleaned. Any insight on this would be appreciated.
Threads: 14
11
Home Port: Kings Park, NY
I owned a 1997 31open/crusaders and the sea strainers were in the same spot. Never had an issue servicing them.... Needed to lift the main hatch not just the day hatch..... Looked at them 1/month and then when winterizing. M2C
Threads: 8
Thanks ReelMagic. When you serviced them did you need to crawl into the engine compartment or were you able to get to them laying on the deck?
Threads: 0
I have a 95 and can easily get to them by opening the main engine hatch and laying on the aft deck and reaching over to the strainers.
Threads: 6
Home Port: Hudson River / Norwalk CT
Vessel Info: 1994 Tiara 3100 Open
Do you need to close seacock valves to check these strainers?
relatively new to me: 1994 Tiara 3100 Open 454 TBI Crusaders
Lifetime racing and cruising sailor throughout New England
More recent home port is upper Hudson river with our Tiara (closer to home)
Threads: 2
Home Port: Oakdale NY
Vessel Info: 2005 32 Open Cummins 5.9 QSB
I have 32 open and port engine is a bitch need crow bar, 4ft, 2x3 and line to open and close. make matters worse the handle fell off now have to remove exhaust hose and turbo elbow to get access and reattach.
