Tiara Sovran Replacement Bulb / Cockpit lighting.
    Does anyone know where to get a replacement bulb for courtesy lighting in the cockpit of a 2008 39 Sovran. The manufacturer is IMTRA. Model ILSH 70241
I believe you need ILW2x4 mini bulbs. I purchased them (not cheap) from Atlantic Marine Lighting but have seen them on Amazon in packs of 10...
(06-07-2021, 08:20 AM)ReelMagic Wrote: I believe you need ILW2x4 mini bulbs. I purchased them (not cheap) from Atlantic Marine Lighting but have seen them on Amazon in packs of 10...
I have a 2006 36 Sovran. I have replaced the bulbs in all my courtesy lights bulbs on the deck with blue LEDs from Superbrightleds.com I am not sure what the bulb number is. The cover of the fixture pulls off and the bulb pushes in. There should be a number on the bulb. I had to replace one of the fixtures in the steps in the cabin. IMTRA does not make fixture with a replaceable bulb any more. They are sealed LEDs. I think it is part BCM3416K-40-4 but I would check dimensions to make sure. Good Luck
John
36 Sovran, Cummins QSC
(06-08-2021, 07:45 AM)jhhall Wrote: I have a 2006 36 Sovran.  I have replaced the bulbs in all my courtesy lights bulbs on the deck with blue LEDs  from Superbrightleds.com  I am not sure what the bulb number is.  The cover of the fixture pulls off and the bulb pushes in.  There should be a number on the bulb. I had to replace one of the fixtures in the steps in the cabin. IMTRA does not make fixture with a replaceable bulb any more.  They are sealed LEDs. I think it is part BCM3416K-40-4 but I would check dimensions to make sure.  Good Luck
Thanks John
I love the 36 Sorvan model you have. Great boat with awesome power for its size.
  DC Panel Volt/Amp Seclector Switch Replacement Peave 4 1,714 11-07-2025, 02:50 PM
  [Tiara Open] Cabin light bulb replacement Bbarroll 2 3,109 06-06-2025, 03:57 PM
Last Post: Joe.dammann
  [Tiara Open] Push button breaker 12v replacement Mydiamond 2 1,754 09-28-2024, 09:01 AM
  2000 3500 Express Cockpit Fridge and Plug Outlet Breaker Location JMGCINCY2023 2 1,729 08-18-2024, 07:22 PM
  LED Lighting Upgrade 3100 Open TWO SUNS 2 6,834 07-11-2024, 02:07 AM
Last Post: Pop Alexandra
WTB Tiara Coronet (1997-2007)
Last Post: JaviAirstream
Today 02:09 PM
Today 10:03 AM
Today 09:58 AM
11-18-2026 05:48 PM
Last Post: joshuawhite
11-18-2026 02:48 PM
