Tiara 3500 Express
When connected to dock shore power, does a Tiara 3500 Express need both shore power connections plugged in to get adequate power for all the boat's AC power needs?
If so, why isn't one shore power cable connection with 30 amp 130 volt power enough?
And:
Are the shore power connections going to all the same 120 volt AC equipment, or does one go to air conditioners and the other shore power connection go to things like tv and stove?
It depends on how your boat is setup. If you have 2 30 amp shore power connections and two separate "sides" on your electric panel with two different 120v meters, then yes both need supplied power. Sometimes you can run a splitter and run everything off of one connection.
Boats are often configured to require 2 30 amp services should everthing need powered simultaneously. For example, hot water tank, two ac units, fridge, ice maker, tv, and microwave all concurrent are probably in excess of 30 amps.
Many can and do run a splitter and live with in 30 amps.
  Refrigerator replacement for 1989 Tiara open/express Halekai 1 3,590 03-08-2026, 11:03 PM
Last Post: Longbeach3910
  2000 3500 Express Raymarine c120 Radar Replacement - Ohio River JMGCINCY2023 5 7,642 09-02-2025, 10:06 AM
Last Post: sluggo
  [Tiara Open] Loose parallel wire behind ignition plate 1996 Tiara open Mydiamond 0 4,360 08-14-2025, 08:05 PM
  [Tiara Open] 1995 Tiara 2900 Gauges cd1154 5 3,785 08-05-2024, 02:27 PM
Last Post: carbon20
Question Autopilot: Hydraulic volume on 2001 3500 Express wallbrad4000 0 1,117 06-17-2024, 07:56 PM
Last Post: wallbrad4000
Tiara 3500 Express00
