Tachometer not working
I have a 2000 40 Express. My port tachometer is jumping allover the place or not working at all. Where do the wires pick up the signal from.
Any ideas on how to look for solution.
 Dave
You have CATS or Cummins?
Not sure about the Cummins, but the CATS connections start right in the front of the engine, centered, above the belt cage. Directly connected to the block is the Aetna sending unit (P/N 8901). There are two wires from that but also a mechanical tach cable that goes to your synchronizer. The location is horrible because the cable gets kinked making a very tight turn between the sending unit and the belt cage. If I were you, I would do the following:
1. Have Glendinning make you a 12" extension (I'd just do both engines). The extension pushes the sending unit outside the belt cage and gets rid of any pressure on the cable.
2. If #1 doesn't fix it, I'd replace the sending unit. Super easy swap-out. They run about $135
3. If #1 and #2 fail, I'd send the tach to Lauderdale Speedo for a rebuild. They're awesome.
4. Last thing I'd try is replacing the tach cable between the sending unit and the synchronizer.
If you have a Cummins, I suspect it's a similar trouble-shooting process, but without the need for #1 above.
(08-29-2022, 11:34 AM)MC1600 Wrote: You have CATS or Cummins?
Thanks. I have Cats 3208 435 HP. I got rid of my the belt cages. I will try the sending unit. Is that part number a VDO part or a Cat part,or Glendinning.
That’s an Aetna part number.
Be real careful getting rid of those cages. If you have pss seals that tap into your HEX, there are water lines that can get easily cut.
(08-31-2022, 11:44 AM)MC1600 Wrote: That’s an Aetna part number.
Thanks again. I do have PSS but the cooling lines are not near the belts
  3500 Exp. engine hatch not working. giff1 1 981 11-17-2025, 09:56 AM
  [Tiara Open] Electrical Issue: Some helm switches not working twilson0929 3 1,673 04-24-2025, 09:03 AM
  [Tiara Sovran] Front stateroom closet light not working. Is there a switch somewhere? Gbrooksct 4 3,747 07-08-2024, 08:49 AM
Last Post: Pop Alexandra
  vdo tach stopped working mnovelli01 2 2,620 08-17-2022, 09:37 PM
Last Post: AyeCandy
  [Tiara Open] Tachometer red light always on- need help 53kemper 3 2,649 07-11-2022, 03:40 PM
Last Post: 53kemper
Today 08:10 AM
» Replies: 4
Oil Filter ?
Yesterday 04:23 PM
Yesterday 01:54 PM
» Replies: 4
Last Post: saywhen
11-14-2026 05:25 PM
3500 Sovran trimtabs
Last Post: drprunner
11-14-2026 03:44 PM
