Windsheild Wipers
I have a 2006 3600 Open. I had a hard time identifying the wiper blades for replacement. I found the Imtra EX2196 Standard wiper blade 31.5" and the EX2177 Standard wiper blade 23.6" to be the exact replacements. While I have been happy with purchasing replacement parts direct from Tiara in the past, they wanted $200 each for the long ones. I was able to buy them direct fro Imtra for $100 each. They also sell the rubber inserts if the metal blade is in good shape.
(11-16-2014, 02:35 PM)Trainman Wrote: I have a 2006 3600 Open. I had a hard time identifying the wiper blades for replacement. I found the Imtra EX2196 Standard wiper blade 31.5" and the EX2177 Standard wiper blade 23.6" to be the exact replacements. While I have been happy with purchasing replacement parts direct from Tiara in the past, they wanted $200 each for the long ones. I was able to buy them direct fro Imtra for $100 each. They also sell the rubber inserts if the metal blade is in good shape.
Tiara is a great company, but they charge full retail for items such as wiper blades. On items they do not manufacture themselves, I would purchase from your local marine supply, or order via the internet if you know what you are looking for. In most cases, all you need is the manufacturers name and a part number, or just a size. Then open your favorite search engine and you will most likely find the items for much less.
Good Luck!
Windsheild Wipers00
