Tiara Sovran Holding tank smell
Gauge has no lights (manual says that means it is between empty and half full) and barely used the head this season so have to believe it is right, but getting urine smell from bilge (gross but accurate) . Still finding my way around the new-to-us vessel. Anyone have suggestions before mechanic show up tomorrow and gets into head work? Thanks.
If the waste tank was ever overflowed to the point liquid came out the overflow then the filter in the vent line must be replaced. Have seen/heard this problem more than once..... Key is to make sure you don't ever let the holding tank get to full..... I empty every weekend regardless of use. M2C Good luck....
(05-05-2017, 04:50 PM)ReelMagic Wrote: If the waste tank was ever overflowed to the point liquid came out the overflow then the filter in the vent line must be replaced. Have seen/heard this problem more than once..... Key is to make sure you don't ever let the holding tank get to full..... I empty every weekend regardless of use. M2C Good luck....
Thanks very much. Will try that
I would also check the vent itself. The screen corrodes and prevents the gas from escaping. You can remove the screen with a dental pick. It's only required on the fuel tank lines. But then you still have to check it for insect nests.
I once had a strong urine smell in my boat too. Found out it was a rat living in the bilge ( remember the old saying, you can smell a rat ).
I assume you flush with fresh water. Salt water flushes present additional problems. I always add the green holding tank liquid from West Marine or Walmart after using the head. It seems to work quite well.
(05-07-2017, 07:01 AM)Uhehner Wrote: I would also check the vent itself. The screen corrodes and prevents the gas from escaping. You can remove the screen with a dental pick. It's only required on the fuel tank lines. But then you still have to check it for insect nests.
Thank you for your reply. We are in Michigan w fresh water. The gauge is working and tank not even close to full. It is Hard to get to the holding tank/ filter but mechanic thinks bilge just needs to be cleaned from non use. Suggested I Pour a few gallons of dawn soapy hot fresh water. Might have done the trick. If not, I'm going to dig into filter next
(05-05-2017, 04:20 PM)holiday3900 Wrote: Gauge has no lights (manual says that means it is between empty and half full) and barely used the head this season so have to believe it is right, but getting urine smell from bilge (gross but accurate) .   Still finding my way around the new-to-us vessel.   Anyone have suggestions before mechanic show up tomorrow and gets into head work?  Thanks.
My 1990 Tiara 3100 vent is clogged. I thinking of just cutting access hole to remove old vent and install new hose and vent.
I will order new vent from Tiara.
Dental pick sounds good, will it take off the vent cover for servicing?
Try adding Zaal Noflex Digestor once a day for each day of use. I tried many product before an old crusty head guy recommended it to me a few years ago and not a hint of odor since.
I just had a similiar situation with my boat.  I pumped out the tank and then added about 5 gallons of fresh water, then pumped it out again. Did this twice, Next added a gallon of water thru the toilet then the sealand tank treatment , smell is gone.
I recommend Zaal Noflex Digestor once a day for each day of use. I just tried it and it does every thing it claims. A little pricey but worth the cost and way more effective than Aqua Kem or TST. You can find it on Amazon.
  1997 4000 Express - Holding Tank Replacement jennyJ 9 5,183 05-26-2026, 07:27 AM
Last Post: frank.koetter
  Water tank level sensors Final Pursuit 4 2,443 10-09-2025, 06:37 AM
  Holding tank collapsing fix giff1 5 3,192 10-18-2024, 06:00 AM
Last Post: egstasea
  2018 38LS Black water tank location Scottbee 1 1,835 03-11-2024, 10:27 PM
Last Post: Scottbee
Question [Tiara Open] How can I repair crack in bottom of holding tank without removing tank? TimmyTime 2 3,320 06-06-2022, 02:16 PM
Last Post: August Rush
Last Post: saywhen
Yesterday 05:25 PM
Oil Filter ?
Last Post: Rick B
Yesterday 04:07 PM
Last Post: Rick B
Yesterday 03:56 PM
3500 Sovran trimtabs
Last Post: drprunner
Yesterday 03:44 PM
36' Open interior lights
Last Post: Rick B
Yesterday 12:22 PM
