Window Washer Solenoid on 4000 Express
Does anybody know where the windshield washer valve solenoid is located on a 4000 express?
Just a guess but I would look behind the dash. Follow the tubing from the windshield to the reservoir. Capt. George
I have not been on a 4000 in a while, but if I remember correctly it is on the forward engine room bulkhead. If its not there, it could be behind the helm. When you find it, let us know.
Good Luck!
I think I found it but almost wish I didn't...
wasabi,
Let us know where you located it. I'm sure others would like to know. Is it outside of the Starboard engine as I suspected?
This gadget is indeed located on the starboard side of the engine room bulkhead. They probably screwed in the solenoid, then put in the exhaust right in front of it. The fit is so tight that I can't even fit a stubby screw driver in there. On top of the solenoid are fistful of wires all zip tied together and hanging over half of the solenoid. I can barely crawl in that space and can hardly see the solenoid . . . so I couldn't take any photos.
I think what I will have to do is just snip the power as well as the water hoses and just relocate a new solenoid to an accessible spot.
Wassabi,
Yes, sometimes that does happen. When the boat was originally assembled, the deck was off the boat and that valve was likely installed from above. Once the deck was on, it is not nearly inaccessible. Unfortunately sometimes items like that are overlooked as to the serviceability. I agree, just cut the wiring and reinstall a new one close by, but in an area where it will be accessible.
Good Luck and let us know how it works out.
Sincerely,
  1997 4000 express shore power issue Salty0ne 10 4,054 03-31-2025, 08:27 PM
  Main Panel Switch needed or 1997 40 mid cabin express Salty0ne 0 747 03-28-2025, 09:44 PM
Last Post: Salty0ne
  2000 3500 Express Cockpit Fridge and Plug Outlet Breaker Location JMGCINCY2023 2 1,619 08-18-2024, 07:22 PM
  4000 Express Rope Light in Master MC1600 6 5,092 08-09-2022, 06:21 PM
Last Post: MC1600
  4000 Express inverter location dan@superstamper.com 2 2,048 08-09-2022, 06:09 PM
Last Post: Jfhaas
Window Washer Solenoid on 4000 Express00
