Tach replacement 1995 33' Open
[attachment=551]I am looking to replace the tach's on my Tiara because they are jumping.
Connections are clean...
Anyone know the current replacement VDO line?
Thank you[attachment=550]
[attachment=552]the twist lock mounting is hard to find
Hello,
Before you buy new ones, see if you can locate the switch on back that is used to select the number of cylinders. Note where it is presently set. Take a small screwdriver and rotate the switch back and forth thru it's range several times and put it back where it was originally set.
See if that clears the problem. Often, those contacts corrode and can cause that problem.
Regards,
Paul
Thanks.
Did the turning of the switches a few times as well as replaced belts.
Seams to have solved the issue.
(08-11-2019, 04:42 PM)Mydiamond Wrote: I am looking to replace the tach's on my Tiara because they are jumping.
Thank you
I think they are VDO Blue Line.
Capt.  George
Last Post: Rick B
  38 open bathroom recessed light bulb twilson0929 3 660 08-26-2026, 06:22 AM
  [Tiara Open] Fireboy FE-241 replacement roboh20 0 481 07-25-2026, 09:15 AM
Last Post: roboh20
Today 08:10 AM
» Replies: 4
Oil Filter ?
Yesterday 04:23 PM
Yesterday 01:54 PM
» Replies: 4
Last Post: saywhen
11-14-2026 05:25 PM
3500 Sovran trimtabs
Last Post: drprunner
11-14-2026 03:44 PM
