Transmission fluid check
I have a 2005 3200 Open with Volvo D6 power
My question is, does the engine need to be running when I check the transmission fluid level ?
Thank you.
Stuart
I'n not sure w/Volvo diesels but with my 6CTA Cummins w/ZF transmissions the fluid is checked right after running. This to ensure the transmissions are warmed up and the fluid is still in the system and it has not drained back into the transmission pan. M2C
Start engine for couple of minutes. Stop engine. Remove dipstick. Insert, but don’t screw in. Check fluid level.
[Image: d5e4658939d5f6e3eba3d37944d4a625.jpg]
  2005 Tiara 3800 ZF transmission Hemlock_SF 8 7,046 04-03-2026, 10:14 AM
Last Post: Reel Pursuit
  How to change transmission oil on 4000 Express w CAT 3208's frank.koetter 7 5,726 09-26-2022, 04:33 PM
Last Post: frank.koetter
  Three Transmission Failures in 39C GToback 2 2,711 07-13-2022, 09:52 AM
Last Post: GToback
  [Tiara Sovran] Warning on EVC "Check Steering Wheel” and getting out of Limp Mode ? Donaldjames 5 5,660 09-09-2021, 01:54 PM
Last Post: Donaldjames
  ZF 305 transmission failure Surly Mermaid 1 3,864 12-16-2017, 09:07 AM
Last Post: tyresmoker
