Tiara Open electrical issue
my hot water heater breaker on the ac panel keeps tripping off when I turn on water heater,,any ideas on the fix solution?
If the breaker is tripping, it's either a weak breaker or the hot water heater is pulling to many amps. Put a meter in the line and see how many amps it is pulling. That will tell you if it is the breaker or the heater.
Donaldjames (11-28-2020)
is the breaker tripping right away or only after it heats up? If right away most likely there is a bad thermostat, heating element or water leaking onto connections (usually from crack in tank). Thermostat and or element are most common causes of direct short and usually can be replaced relatively easily and are almost always replaced together. Unfortunately your 43 will require you to crawl over engine and stand on your head for access. Probably easier to pull cablemaster tub out and shimmy along the outboard side of the starboard engine.
To rule out breaker you can also swap with another breaker of similar capacity (such as an ac compressor). Just make sure you disconnect shore power while moving.
I had a similar situation on my motorhome and it turned out to be a shorted out heating element. I would also highly consider the breaker going bad as circuit breakers in some cases are toggled on and off quite a bit and can wear out . Best of luck and let us know what you find out .
it was a bad thermostat,thx for the input.
[-] The following 1 user Likes dduca@comcast.net's post:
Donaldjames (12-19-2020)
  [Tiara Open] 2005 TIARA 2900 OPEN DC ELECTRICAL SCHEMATIC COPY HIGH SPIRTED 2 2,749 07-05-2025, 12:54 PM
Last Post: HIGH SPIRTED
  1997 4000 express shore power issue Salty0ne 10 3,996 03-31-2025, 08:27 PM
  Glendinnning cable reel issue OurHighLife 3 2,477 11-05-2022, 09:11 AM
  [Tiara Open] electrical issue dduca@comcast.net 3 3,723 12-12-2021, 04:04 PM
Last Post: Donaldjames
  [Tiara Open] 2004 32 Open DC Electrical Panel fixkr 0 1,620 11-11-2021, 10:22 PM
Last Post: fixkr
electrical issue00
