Tiara Sovran Slave/Port Throttle
I took possession of a 2006 3600 Sovran. At the sea trial. I had no throttle on the port engine. After manual moving the throttle body at the engine the throttle lever started to then work. I did notice that the port/slave throttle then felt like it had a noticeable amount of increased tension as compared to the starboard/lead throttle lever. When the engine sink Botton is turned on the slave no longer has tensions in the throttle movement. Later I tried to recreate the the loss of throttle to troubleshoot. I was able to recreate it while at idle and then turn on engine sink button, move the slave throttle to full open and then back closed and turned off engine sink. Now when i apply some throttle to the slave/port handle no tension as before and also no throttle/engine response. Its as if the sink is still engaged. I then repeated the previous steps slower and all seemed to work again.
If that happens again cycle the sync button off -on -off and give it a couple seconds. Always remember to switch off sync button before returning slave throttle to idle.
Thank you for input. That does make sense. When not in sink mode. Does it sound right for the slave handles to having a greater feeling of resistance than the lead handles. Or is an adjustment needed to make the resistance the same in both handles.
If you are using a Glendinning there are a few cables and a disconnect for the slave in the unit itself. Sounds like the disconnect is a bit sticky and not reconnecting easily. These can be serviced and lubricated to help with the cable connections. Take a few minutes and go look at the unit. A little cable lube and some spray lithium grease and I bet it starts working correctly.
There are adjustments that can be made in the upper control unit for friction and throw.
  [Tiara Coronet] Port engineer and electronics quit running at same time Tmikac 3 875 07-07-2026, 07:47 AM
Last Post: Tmikac
  [Tiara Open] 2001 3500 Open no fuel to port engine??? wow 4 3,892 05-31-2024, 11:32 AM
Last Post: RMS
  Throttle & Shift handle replacements for a 93 29 Open 29opensoon 1 1,380 11-27-2023, 06:26 PM
  Port light or port hole window lwaking dbruce222@gmail.com 5 4,328 05-25-2023, 01:15 PM
  [Tiara Open] Access to Port Wiper Motor on 3800 Open Tony Saitta 3 3,453 04-09-2022, 02:48 PM
Last Post: rotellats@gmail.com
