Tiara Convertible 2006 3900 fresh water breaker trips
New to me 06 39 convertible,  2 fresh water pump breakers, when running shower or cockpit wash downswater
 breaker pops when both breakers are on. Replaced shower box float and flo jet pump, also get a pulsing on all lights on boat when running galley sink?  Any suggestions on what is going on?  Thanks for any help, this is driving me nuts! Cristina
Sounds like the fresh water pump or pumps are drawing to much current.... May need a rebuild/replace.. Just a guess
(08-13-2021, 07:48 AM)misscristina Wrote: New to me 06 39 convertible,  2 fresh water pump breakers, when running shower or cockpit wash downswater
Sounds like you have low batteries on the house side and when you are running the freshwater pump it is drawing enough amperage to make the lights dim and breaker pop if the draw is too great.
When you are hooked up to shore power and shore water, with your freshwater pump turned off on the panel does the issue still exist?
OR -
Without being hooked up to shore water but being on shorepower with your battery charger on in the panel and freshwater pump on in the panel does it still happen? If it doesn’t that helps identify low batteries, since when on the charger it should for a short term keep the lights from dimming even for a little bit till the amperage draws down.
Just my thoughts to start to try to diagnose it, how old are your batteries, if newer you could have a bad cell causing issues and then lastly it could be a short or bad ground someplace which would pop breakers and also fuses if so equipped.
Having the same problem except the breakers don’t trip. I just have to rest them. I’ve replaced all six batteries and one alternator. Can’t figure out why resetting un tripped breakers will fix the problem. Once the water is running the pumps just keep it coming. On shore power the fresh water will just stop working. I reset the breakers and alls well. Was underway for several hours fishing and it took about 20 minutes of resetting to get the system on again. The pump felt warm to the touch even though it wasn’t running. Maybe an internal thermal switch on the pump? Any suggestions?
Sounds like you could use an accumulator tank down stream of the pump.  If you already have one, it made need to be charged. The tank helps take some of the loads off the pumps
  [Tiara Sovran] Wiper Blades 3900 Sovran Euphoria38 1 613 08-31-2026, 10:34 AM
Last Post: Herrema4
  [Tiara Convertible] How do I repair a broken wash down/city water connection plate? Peave 4 1,843 05-12-2026, 10:18 AM
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,959 02-23-2026, 11:01 AM
  Water alarm in the diesel filters maxcav 0 583 02-15-2026, 05:34 AM
Last Post: maxcav
  Water if forward bilge after rain lenoah 0 700 11-21-2025, 05:53 PM
Last Post: lenoah
