No alarm beep when turning ignition key 454 crusader gas engine
I am have an intermittent issue.
When I turn my starboard key … no beep.
I tightened the wires on oil sending unit.
Replaced oil pressure alarm..
It worked for awhile..
Now I found I have to unplug a connection on the starboard side front of my engine. Not sure what this does.. but it gets the boat started.
Usually after a few days of non use or heavy rain. (Just my hopeful observation)
Any ideas of what could be happening?
I am assuming a loose connection or something is being re-set when I unplug?
First thing I would do is remove, clean, and reinstall the ground to that motor. If it looks questionable in any way, just replace it.
Mydiamond (09-26-2021)
Closing out this thread.
After tracing the wire and replacing all connections.. I traced back to the relay.
It is on top on the engine in the breaker box.
Cleaned connections and replaced the relay.
It seems the relay was sticking.
Easy DIY repair..
all is good again
  Tiara 4000 Express Cummins 6CTA 8.3 In-Frame Engine Rebuild Jack Aperio 3 2,890 05-23-2026, 03:27 PM
Last Post: Capt. Paul
  2007 3600 Open QSB 5.9 380 hp Propeller and Engine Performance Test today Roweje 1 1,305 08-06-2025, 09:41 AM
Last Post: Sapphire
  Cummins 6CTA 8.3 Engine Rebuild - Additional Photos Jack Aperio 3 2,443 07-08-2025, 09:41 AM
  Engine Surveyor czarcone 2 2,610 10-13-2023, 05:27 AM
Last Post: czarcone
  [Tiara Sovran] Prime Diesel Engine Donaldjames 3 2,398 04-15-2023, 06:43 AM
Last Post: MC1600
No alarm beep when turning ignition key 454 crusader gas engine00
