Threads: 45
2
Home Port: Long Island Sound
2 of the four hatches on the floor on the cockpit on my 2002 3100 Open are cracked and need to be replaced. I looked at it today and with the floor molded for the hatches how do you get some kind of tool under them to pry them out of the sealant they are bedded in? At first thought I am thinking about cutting the flange with a dremmel to get it started. I don't want to pry against the non-skip floor in fear of damaging it. Any guidance is appreciated.
Threads: 0
Home Port: Lake Erie
Vessel Info: Tiara 3300 open, 1997 crusader 7.4 XLI
Pursuit 2550 cc cuddy 1990 twin 200 Yamaha
One thing that will help is using Boatlife “Release” to soften and loosen up the sealant that is holding them in place. This was the only way I was able to replace the ones on my 33
Threads: 14
2
I replaced all mine on my 98 31 Open. Heat is needed to soften the 5200. that an a really thin blade. Lots of patiance!
Threads: 45
2
Thanks guys. So there is no silver bullet.
Threads: 3
Vessel Info: 1989 3300 Open Crusader 454s
You can use commercial grade goo be gone to soften the 5200. Worked great when I had to replace an old transducer previous owner used 5200 to bed. Soaked it good and let sit for a day, soaked again, and the next day was soft enough to scrap out with a putty knife
Threads: 45
2
Thanks will give it a try. Gotta love the strength of 5200, until you need to get it off.
Threads: 3
20
Home Port: Lake Michigan
Debond works ok for releasing 5200. Still takes a lot of patience and multiple applications to clean it all off, but it is a lot easier than using solvents.
