Trans Oil Pressure
Hello</p>
Bought a 1999 35 Open a couple of months ago. One thing that worries me is the Trans Oil Pressure gauges read a high psi. The gauges go from 0 to 400psi and are reading 350 to 400 when running. Being new to this boat I do not know where normal running pressures should be but do not like seeing any gauge showing the high end of the spectrum when running. Have Cummins 5.9's on the boat and have another thread going concerning my 2700 rmp's at wot. Could the two be connected? The other thread us found in the Tiara Open area</p>
Thanks for any input.</p>
</p>
Kent</p>
Kent
1999 Tiara 35 Open, Cummins
Kent, your Trans Oil pressure is just where it is supposed to be. Not to worry.
Thank you! Peace of mind.......
Kent
  Rubber Damper Failure between ZF trans and 3208's JonesE 6 2,052 08-06-2025, 05:38 PM
Last Post: JonesE
  Zf 302v-ld trans prop shaft removal Docked Wages 3 3,025 02-19-2023, 12:27 PM
Last Post: Richard.Janek
  [Tiara Open] High Crankcase Pressure "Blow By" m.t.bentz 0 1,172 02-08-2023, 11:29 AM
Last Post: m.t.bentz
  Trans oil honest mark 3 4,500 11-29-2019, 01:07 PM
Last Post: honest mark
  trans oil cooler honest mark 2 3,631 09-18-2019, 07:48 AM
