Fresh water tank repair
I own a 1986 Tiara 2700 Open with twin Crusader 270 inboards.  The 30 gal. aluminum fresh water tank would leak down in about 3 hours.  I keep the boat on a trailer at my shop.  The tank is located under the 2 90 gal. fuel tanks.  I didn’t want to drain and pull both tanks to be able to remove the water tank.  I did have access to the back end of the fresh water tank with the fill, vent and discharge ports. I used an endoscope to try to locate the leak, but could only determine that it was in the forward section of the bottom of the tank.  I flushed the tank and completely dried it with rags and compressed air.  I dropped the trailer tongue to the ground which gave a forward tilt to the tank.  I inserted a 3/4” hose thru the fill port and along the inside past the baffles to the front of the tank.  I poured about 8 oz of liquid Flex Seal down the hose.  After the hose emptied, I jacked up the starboard side for about 10 minutes, then the port side for about 10 minutes.  After that I removed the jacks and let it remain flat.
I let it sit for a day and a half then filled it with water.  No leak.  Since this tank is not used for potable water, the Flex Seal should present no problem.  I’ll see how it holds up this year and will update if it starts leaking again.  Thought this might come in handy if anyone had a similar problem.
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 480 08-18-2026, 02:11 PM
  [Tiara Convertible] How do I repair a broken wash down/city water connection plate? Peave 4 1,683 05-12-2026, 10:18 AM
  [Tiara Open] 2001 3800 Open Holding Tank cap that hold sensor and washdown twilson0929 0 839 05-12-2026, 10:18 AM
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,805 02-23-2026, 11:01 AM
  [Tiara Open] 93 3100 fuel tank sending unit. Joeboch348 1 668 02-18-2026, 09:15 PM
