Tiara Open 2006 Tiara 42 Open Transmission
Our transmission needs to be rebuild and they are saying they need to cut a larger hold in the helm area.   Is there another way of getting the transmission out?
Will it clear the aft access hatch? I’ve seen a yard use an airbag with rails set under the gear then once moved back off the flywheel inflated high enough to slide the gear over the stringer and allow a forklift to yank it out through the aft hatch. If the gear is too wide then the only other option I know of is to pull the floor hatch above the engines. It’s a lot of work to disconnect plumbing, electrical, seats etc. but at least you aren’t cutting the thing up and then trying to repair it and match gel coat / non skid.
Sorry to hear and good luck
  2000 3500 Open - Engine Sync Switch (7.4 MPI's) BIG_D 5 2,141 08-14-2026, 05:33 AM
  '93 TIARA 2900 OPEN ENGINE OVERHEAT WITH COOLANT/WATER POSSIBLY MIXED WITH OIL Showtime 3 2,083 05-23-2026, 02:12 PM
Last Post: Capt. Paul
  [Tiara Open] Repowering a 1992 3300 Open WOLFDAWG71 1 1,325 02-17-2026, 06:46 AM
  [Tiara Coronet] ZF Transmission Noise Ceili 4 1,630 10-05-2025, 07:55 PM
  [Tiara Open] 2900 open - 454 mounts North000 0 694 06-12-2025, 08:21 PM
Last Post: North000
