MORE POWERFUL RAW WATER WASHDOWN
would like to install a more powerful raw water washdown on my boat, is that a big job? is it as simple as just changing the pump to a more powerful one? do i have to change any plumbing or fuses? mine is just too weak of stream for my liking, thanks in advance.
You will need to check the breaker and wire size to your current pump and make sure it will be sufficient for the new one.
I changed my nozzel and hose last year and it made a difference in mine. Not a huge improvement, but enough for me to keep my current setup for now.
I changed mine to 7 gpm it was a improvement but not what I was hoping for. I think the quick connects and the diameter of the hose are slowing the gpm out of the nozzle. Make sure your strainer is clean, In south Haven we had terrible duck weed last year and it will plug up anything. I know in ludington you are graced with really clean water but there will still be some in there.
thank you guys......
Look fir higher PSI pumps, not just GPH
(02-13-2021, 12:20 PM)OurHighLife Wrote: Look fir higher PSI pumps, not just GPH
Size matters, use the largest ID  piping you can get and match up the ID on everything
What kind of hose are you using on deck? The small diameter spiraled hoses I think work the best to keep pressure up.
  [Tiara Open] 1995 Tiara 43 Open water tank and door/stairs removal chrisrobinson99 1 2,183 03-11-2021, 06:24 AM
Last Post: bruce33
  Want to add raw water washdown in 38 Open CaptGregSTX 9 11,449 06-27-2020, 11:02 AM
Last Post: jrblough@mtu.edu
  Removal of steps to access wiring and water tank. RJOL3 3 4,906 07-10-2017, 10:25 AM
Last Post: ddfour1
MORE POWERFUL RAW WATER WASHDOWN00
