Tiara Open 2006 36 Open Racors
I recently purchased a low hour 2006 36 Open with Cummins 425s in it. With 380 all fresh water hours. I tok her to Long Island NY via Saint Lawrence River, Lake Ontario and the Oswego and Erie Canals to the Hudson River. It started a mild surge so I changed the razor filters. On my last boat I would close the supply valves and run the engines for a few second to drain down the racors and not spill any fuel. I did the same with this boat but fuel was still flowing into the filters and the bilge. I guess it is possible the valve diagram is not correct but maybe I am missing a secret to do this neatly. Ideas?
Racors shouldn’t “drain down” when you close the supply valve. If it did that on your old boat, the Racors had a leak allowing air in under strong vacuum. What you were doing is not a recommended procedure. Get a bucket that fits underneath.
Agree with JMK.
(08-11-2023, 11:45 PM)jmk Wrote: Racors shouldn’t “drain down” when you close the supply valve.  If it did that on your old boat, the Racors had a leak allowing air in under strong vacuum.  What you were doing is not a recommended procedure.  Get a bucket that fits underneath.
It did not drain down. The fuel kept flowing into the uncovered filter even with the supply valves labeled from the factory closed.
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,531 05-22-2026, 06:41 PM
