Tiara Open Trim Tabs
Trim tabs on Tiara 3800 Open do not open.  Bennett Pump oil is full.
Is there a relay switch associated with the switches on the dash? If yes then where is it located?
(09-25-2018, 06:43 PM)Tony Saitta Wrote: Trim tabs on Tiara 3800 Open do not open.  Bennett Pump oil is full.
could be fuse on dash......(where are the other fuse resets are) or relay mounted down near pump.
Capt. Brett M. Sause
USCG Master Licensed Captain
443.220.4339
www.themarineminute.com
Last Bennett system I worked on had no relays. 12V ran direct from switch panel to reversing motor and valves in the pump. Regardless first check for fuse/breaker per previous post, then check for 12V at pump.
.pdf   Pic5 EMI Suppressor.pdf (Size: 139.28 KB / Downloads: 117)
.pdf   Pic3 EMI Suppressor.pdf (Size: 122.08 KB / Downloads: 57)
.pdf   Pic4 EMI Suppressor Model & Serial.pdf (Size: 146.03 KB / Downloads: 40)
.pdf   Pic5 EMI Suppressor.pdf (Size: 139.28 KB / Downloads: 117) Bennett Trim Tabs on Tiara 3800 open would not open.  We finally found that the problem was the faulty Charles Industries 12/24 V EMI Suppressor.  I cannot find a replacement part as Charles Industries no longer make them.  We found that the trim tabs opened when we bypassed the suppressor. A couple of questions:
1) Are there any negatives if we bypass the suppressor and
2) Does anyone know if there is a similar replacement for the Charles Industries part?
3) Is there somewhere to find a second hand one.
Model number: 93-SPRSR-A
Serial: 01050012
Photos Attached
Where is the Charles EMI Isolator located?????? Don't remember seeing IT on on my 2003 38 OPEN
The EMI Suppressor is located next to the trim tabs pump,  aft where all the auto pilot steering gear is located
(09-25-2018, 09:24 PM)jclark003 Wrote: Last Bennett system I worked on had no relays. 12V ran direct from switch panel to reversing motor and valves in the pump. Regardless first check for fuse/breaker per previous post, then check for 12V at pump.
I have the same issue, to bypass it did you just connect the "Ins" to the "Outs" ????
Thanks.
HarmoneE²
Tiara 3800 Open, Onset MA
Did you by chance find a replacement? My 2001 3800 Open tabs won’t go down either. I can hear it buzzing but the tabs aren’t moving.
  [Tiara Open] Trim Tab Hydraulic System Bob's Boat 0 433 07-19-2026, 02:41 PM
Last Post: Bob's Boat
  [Tiara Coronet] Trim tab settings Koast2Koast 0 633 05-23-2026, 04:34 PM
Last Post: Koast2Koast
  [Tiara Sovran] 3500 Acces to Clarion Remote and Trim Tab Controler LastDance 0 777 04-25-2024, 07:37 AM
Last Post: LastDance
  Tiara Express 3500 Trim Tabs System location? neto 2 2,729 06-26-2021, 08:23 PM
Last Post: neto
  Bennett auto trim installation reeltimebrad 3 3,519 03-29-2021, 03:49 PM
Last Post: ardoski14
Yesterday 01:18 PM
Yesterday 01:17 PM
10-30-2026 06:10 PM
