Tiara Open 36 Open 2009. Shower drain
Dear Tiara Owners club,
Last week I was doing a check in the bildge and and I found lots of fresh water. I suspect that it is from the shower drain as I can hear it draining in an open space, but i'm not so sure. If anyone knows the answer I would really appreciate it.
Thank you
Sounds like (no pun intended) your shower waste line has become disconnected from the shower drain.
(12-15-2024, 05:42 PM)bruce@bigrivergroup.com Wrote: Sounds like (no pun intended) your shower waste line has become disconnected from the shower drain.
Thank you, I will check on it
Might be obvious, but do you realize that it drains to a sump box with a pump in it? If the pump is clogged (or has failed), it will just overflow into the bilge.
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 489 08-18-2026, 02:11 PM
  2001 38’ Open interior table base removal twilson0929 3 907 07-07-2026, 08:13 AM
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,530 05-22-2026, 06:41 PM
