Threads: 13
Home Port: Bellevue, WA
Vessel Info: 1995 31 Open with fuel-injected 454 Crusaders
The sliding door to our 1995 31 Open seems off its track. Does anyone have experience repairing such doors?
Thank you
Threads: 14
11
Home Port: Kings Park, NY
I owned a 31 open, 1997, and adjusted the door several times when it didn't slide smoothly. Sounds like the adjustment on the bottom has moved. Access is easy. On the bottom of the door on each corner is a plastic cover that can be snapped out (similar on the top of door as well). Once removed you will find the adjustment.. Requires an Alan wrench. Hope this helps.
