Tiara Open Zf280 transmission pressure
I have a 01 3800 Open with Cummins 8.3 / 450 Diamonds and ZF280 transmission. Recently my port transmission is not returning to its normal low pressure when placed in neutral. It returns only halfway between the 300 plus psi in gear and where it traditionally has returned to out of gear (I don’t recall this exact psi on the analog gauge). The sensor on the transmission is maybe 3 years old. Any advise on the issue or cause is appreciated.
The electrical sender/analog gauge system is prone to false readings, especially as things age (like the wiring/connections). Step 1 is to get a reading with a fluid filled mechanical gauge. Temporarily remove the sender and replace it with a mechanical gauge and get readings in F/N/R. Get a gauge good for about 600psi, less than $20 on Amazon. Use a thread sealant. The connection for the sender is 1/8 NPT. Normal pressure in N is about 70psi.
Great advise, ordering the gauge today.
  Oil pressure gauge, tank indicators lenoah 8 2,181 10-31-2025, 11:15 AM
Last Post: lenoah
  Oil pressure sending unit on twin disc Renegade93 0 1,299 06-14-2022, 04:57 AM
Last Post: Renegade93
  Transmission Oil Change Russf 2 5,206 02-25-2017, 10:58 AM
Last Post: Russf
  Transmission Fluid Venting through hull desjef 3 5,718 08-05-2016, 02:19 PM
Last Post: desjef
  Transmission knock Whefour 2 4,135 02-29-2016, 09:19 PM
Last Post: DavidB
Zf280 transmission pressure00
