2001 3100 open generator runs but doesn't generate electricity
I have a factory installed Westerbeke generator with very low hours(less than 25) in a freshwater boat.
I have owned the boat for 3 years, with no issues. I have run the generator 4 times this year with no issues .I started it today and it ran and pumped water for 20 minutes, but I was not getting any current out to the generator to power the boat so I shut it down and restarted it twice but no change.
What should I be looking for?
Thanks for any advice
First step--check the breakers. There are breakers in the cabin but also right on the generator itself, both DC and AC--you're looking for the AC breakers.
I checked them today and the fuse.
All looked good and in order
If you're comfortable working around high voltage, go through this step by step.  Otherwise, it's time to call a pro.
(08-25-2025, 07:22 AM)hiccup Wrote: If you're comfortable working around high voltage, go through this step by step.  Otherwise, it's time to call a pro.
I'm having the same issue. I've tried to download your troubleshooting doc but have been unable to download it. Could you get it to me another way please?
Sent from my Pixel 8 Pro using Tapatalk
(11-14-2025, 12:15 PM)robin.joshua Wrote: [Only registered and activated users can see links Click here to register]
  [Tiara Open] Main DC Breaker for 1995 Tiara 36 Open petrienorris@gmail.com 2 964 07-15-2026, 08:06 AM
  1988 3300 Open - Voltage drop when lowering engine hatch or honking horn Pluto 3 1,249 03-24-2026, 09:46 AM
  Replacing Inverter on 1998 Tiarra 3100 Pknappe 1 516 03-24-2026, 09:36 AM
  2006 3600 Sovran Generator Battery location Final Pursuit 0 767 08-09-2025, 07:49 AM
  [Tiara Open] 2005 TIARA 2900 OPEN DC ELECTRICAL SCHEMATIC COPY HIGH SPIRTED 2 2,741 07-05-2025, 12:54 PM
Last Post: HIGH SPIRTED
2001 3100 open generator runs but doesn't generate electricity00
