Tiara Convertible How do I repair a broken wash down/city water connection plate?
(05-08-2026, 03:27 PM)Peave Wrote: The wash down connection on my Pursuit 3400 Express broke when I was  de-winterizing. Pictures attached. I’ve never messed with this type of water connection so I’m leery of disconnecting the supply lines to repair it.  How show I fix this?.
[/quote]
Attached Files Thumbnail(s)
The whole assembly can be removed if you take out the 4 screws that hold plastic panel to the boat. I would check with tiara and see if the piece is still available. If it’s not you could cut a stainless plate to cover the damaged area.
These are the supply lines.
The supply lines use whale product fittings & tubing (metric 15mm). You can release the supply lines at the connecter relatively easy... Take a carefull look at the white collar with the gray ring around the blue water line & inside the white collar... The method to release the blue water line from the white connector is by pushing IN (into the white connector) the gray ring which will release the water line. the white connector has an O-ring on the inside. There may be a locking clip preventing the gray collar from going into the white collar. remove the locking clip if needed
Hard to follow, but that part that is broken is made by SSI plastics. Call them with dimensions.
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,870 02-23-2026, 11:01 AM
  Water alarm in the diesel filters maxcav 0 533 02-15-2026, 05:34 AM
Last Post: maxcav
  Water if forward bilge after rain lenoah 0 644 11-21-2025, 05:53 PM
Last Post: lenoah
  Transom Door/Gate Repair MC1600 4 4,598 08-25-2025, 10:53 PM
Last Post: Splendor
  [Tiara Open] Water under Quartz flooring in head benmaser 0 748 06-16-2025, 02:24 PM
Last Post: benmaser
Today 08:10 AM
» Replies: 4
Oil Filter ?
Yesterday 04:23 PM
Yesterday 01:54 PM
» Replies: 4
Last Post: saywhen
11-14-2026 05:25 PM
3500 Sovran trimtabs
Last Post: drprunner
11-14-2026 03:44 PM
