Center power window on a 1997 33 open
Have had the center window out twice now. Both times to replace seals. Second time installing doesn't seem to seal as well now. I am not sure if it is seated in the top slot right. Anyone out there have a better way of installing this better. Seems like the window isn't sitting in the frame flat from top to bottom. Doesn't even look like it is sealing at the bottom of the window.
thanks
Kurt
(05-25-2015, 08:21 PM)kurts52 Wrote: Have had the center window out twice now. Both times to replace seals. Second time installing doesn't seem to seal as well now. I am not sure if it is seated in the top slot right. Anyone out there have a better way of installing this better. Seems like the window isn't sitting in the frame flat from top to bottom. Doesn't even look like it is sealing at the bottom of the window.
thanks
Kurt
hi Kurt,
Sorry I don't have the answer but hoping you can help us.  We need to replace the seal for the same window and not sure where to source it from. Can you recommend a website?
Judy.
Judy
Getting the window out is not to bad. Putting it back in is a real pain. If you sent me your e-mail address I will sent you the diagram that Tiara gave me. It will tell you everything you need to know and the part numbers with pics. Note the way the "L" seal is orientated on the window. Its not the way that you would think it should go. Question for you, is your center window flush with the main frame on the windshield on the left and right side of it. Top to bottom.
kurts52@yahoo.com
Kurt
  [Tiara Open] Main DC Breaker for 1995 Tiara 36 Open petrienorris@gmail.com 2 717 07-15-2026, 08:06 AM
  1988 3300 Open - Voltage drop when lowering engine hatch or honking horn Pluto 3 1,175 03-24-2026, 09:46 AM
  2001 3100 open generator runs but doesn't generate electricity lakesidevu 5 2,449 11-14-2025, 01:01 PM
  [Tiara Open] 2005 TIARA 2900 OPEN DC ELECTRICAL SCHEMATIC COPY HIGH SPIRTED 2 2,704 07-05-2025, 12:54 PM
Last Post: HIGH SPIRTED
  1997 4000 express shore power issue Salty0ne 10 3,797 03-31-2025, 08:27 PM
Center power window on a 1997 33 open00
