Head door locked
I have a 1998 3100 open and while cleaning this weekend my wife inadvertently locked the door to the head then closed it from the outside. I do not see any way to access the head compartment to unlock the door. Does anybody have any suggestions?
Joe T
Higganum, Ct.
I would try using a sharp knife blade against the top of the plunger and sliding it in. Then push or pull on the door to hold the plunger in place and take another bite. Repeat until it opens.
You did not say if the door swings in or out. If it swings out a credit card may work against the plunger. Capt. George
I tried to force a thin flexible steak knife, then a small screwdriver between the plunger (bolt) and the receiving hole but the space was too tight to fit anything between them. I think my next attempt will be at the hinge pins?
Thank you for your consideration.
Joe T.
If you want to widen the space put two wide putty knives in the slot and then jam a flat blade screwdriver between them. That way you do not mar the wood. Then back to the sharp knife trick. Capt. George
Oh no. I just did the same thing on my boyfriends boat. How did you get it open?
Please help
Lisa
  bathroom door handle fuzzy 2 634 07-18-2026, 05:43 PM
Last Post: fuzzy
  [Tiara Open] Access cover to sliding door on 43 open MariTime2 0 992 12-14-2025, 05:34 PM
Last Post: MariTime2
  Transom Door/Gate Repair MC1600 4 4,540 08-25-2025, 10:53 PM
Last Post: Splendor
  [Tiara Open] Water under Quartz flooring in head benmaser 0 731 06-16-2025, 02:24 PM
Last Post: benmaser
  1990 3100 open - can I add a transom door? 604.jim.smith@gmail.com 0 647 05-27-2025, 04:49 PM
