Aluminum Windshield Parts
I have a 1990 3600 Open that has a painted aluminum framed windshield. There are some small corrosion bubbles at some of the joints.
Does anyone know where I can buy these extrusions? New or used.
What have you guys done in the past?
Thanks,
Dennis
Trying to replace a part in that frame is going to be a monumental job. IMO those screws will NOT come out easily. The usual method to remove ss screws from aluminum is to apply lots of heat with a torch.
Why not grind away the corrosion, fill the voids with Bondo and paint it with Awlgrip?  I just painted the window frames in my 36 convertible with Awlgrip and they look like new. Pitting was minimal and barely noticeable once painted.
Thanks. Yeah I kinda figured the screws would be a mess. Maybe I'll do some localized sanding and see how good I can make it look.
Capt. George, did you remove the frames or do them in place?  That's also on my project list, and have seen some post on the dangers of removing those frames.
Thoughts?
It would be almost impossible to remove the frames without disassembling the boat.
I refinished them in place. Careful sanding and lots of masking tape. Awlgrip was easier to apply than I expected. I brushed the paint and then tipped it with a foam brush for a perfectly smooth finish.
Those windshields were custom made, so buying the extrusions is not an option. As mentioned above, removing the windshield frame is a monumental job and would not be worth it. As captain George says, sand, fill, prime and paint is likely going to your only solution.
Good Luck!
  Windshield Leak tip TIARACRREP 35 41,616 09-23-2026, 11:53 AM
  Windshield Wiper Arms and Blades Lafobrian@gmail.com 17 16,313 06-20-2026, 11:59 AM
Last Post: nylakeshome
  2000 3500 Express Windshield Wiper Blade Replacements JMGCINCY2023 5 3,028 04-19-2026, 06:48 PM
  Parts for Tiara donwal 2 1,149 11-07-2025, 09:07 PM
Last Post: Mmiklosz
  [Tiara Open] 1989 36 open windshield weep holes? BurdenLSU 1 1,180 09-17-2025, 10:43 AM
