Transmission knock
i looked at a 31 open listed for sale that has a knocking sound coming from the starboard engine when at idle. Sound disappears when put into gear. I'm told the noise is coming from the transmission and is a clutch spring and is not an issue and is common. Anyone have this same condition?
Sounds like the damper plate assembly ( P/N 97334 ) has a broken or collapsed spring. You need to pull the transmission and flywheel housing and replace the damper. Yes it's fairly common. A rough idle or miss will also cause the noise as the plate tries to smooth it out. Capt.  George
Get a good survey and negotiate the repair as a needed repair before the sale.  That way common or not it is fixed before you have to deal with it.
  [Tiara Open] Zf280 transmission pressure twilson0929 2 989 08-11-2025, 07:19 AM
  Transmission Oil Change Russf 2 5,212 02-25-2017, 10:58 AM
Last Post: Russf
  Transmission Fluid Venting through hull desjef 3 5,726 08-05-2016, 02:19 PM
Last Post: desjef
  volvo D6-310 Hurth transmission johnhesch 2 4,024 10-12-2015, 07:54 PM
Last Post: johnhesch
  Hurth / Mercruser Transmission aksmith 0 2,493 07-03-2014, 11:56 AM
Last Post: aksmith
Transmission knock00
