Transmission knock
i looked at a 31 open listed for sale that has a knocking sound coming from the starboard engine when at idle. Sound disappears when put into gear. I'm told the noise is coming from the transmission and is a clutch spring and is not an issue and is common. Anyone have this same condition?
Sounds like the damper plate assembly ( P/N 97334 ) has a broken or collapsed spring. You need to pull the transmission and flywheel housing and replace the damper. Yes it's fairly common. A rough idle or miss will also cause the noise as the plate tries to smooth it out. Capt.  George
Get a good survey and negotiate the repair as a needed repair before the sale.  That way common or not it is fixed before you have to deal with it.
  [Tiara Open] Zf280 transmission pressure twilson0929 2 1,121 08-11-2025, 07:19 AM
  Transmission Oil Change Russf 2 5,340 02-25-2017, 10:58 AM
Last Post: Russf
  Transmission Fluid Venting through hull desjef 3 5,896 08-05-2016, 02:19 PM
Last Post: desjef
  volvo D6-310 Hurth transmission johnhesch 2 4,126 10-12-2015, 07:54 PM
Last Post: johnhesch
  Hurth / Mercruser Transmission aksmith 0 2,557 07-03-2014, 11:56 AM
Last Post: aksmith
Today 08:10 AM
» Replies: 4
Oil Filter ?
Yesterday 04:23 PM
Yesterday 01:54 PM
» Replies: 4
Last Post: saywhen
11-14-2026 05:25 PM
3500 Sovran trimtabs
Last Post: drprunner
11-14-2026 03:44 PM
