Threads: 1
Home Port: Chester, MD
Vessel Info: 1997 Tiara 3300 Open
Twin Crusader 454 7.4's
Feel really dumb asking this question...I am the new owner of a 33 Open with a Kohler 5KW generator. It worked perfectly during the survey. I didn't use it for first 4 or 5 weeks, and when I did it started fine, but the auto shut down kicked in a couple of minutes into running. All the seacocks are open and it appears to function fine for those first few initial minutes of running. Anybody have any suggestions on what I am doing wrong or might be broken?
Threads: 14
11
Home Port: Kings Park, NY
02-26-2017, 08:02 AM
(This post was last modified: 02-26-2017, 08:03 AM by ReelMagic.)
Assuming the Oil Pressure is OK I suspect you need to replace teh raw water impeller... The unit will shut down after a few minutes if it doesn't sense water flow to cool the engine/heat ex-changer... M2C
