Wiper arm replacement
We have a 31 2003 LE.
I want to replace the wiper arm as a result of the tension spring becoming rusty.
The windshield trim limits access to the place the arm attaches to the motor, and I am not able to get it off the motor shaft. I can
Wiper arms can be held on the splined shaft by different methods. I do not remember how the 31 Tiaras where done.
Some have a spring clip. Look or feel under the arm by the shaft and see if there is a little flat stainsess clip that can be pulled or pushed. It won't come off, it just retracts enough from a groove in the splined shaft to allow you to pull (you may have to wiggle while pulling) while you pull or push that little clip or spring.
Some have allen set screws to hold the wiper arm to the shaft. I have not seen this style in a long while and I believe the 31 LE uses the clip on version, but look for allen screws just in case.
If the arms are corroded to the shaft, you may have to spray some penetrating oil up under the arm and let it sit for a while. Place a rag around the area when spraying to keep the mess to a minumum.
Good Luck!
Dremel tool works fine if you are cautious not to dig into the splined shaft hub too much. But before you go there, see if you can find an open ended box wrench to slide under there and pop the arm off.
  [Tiara Sovran] Wiper Blades 3900 Sovran Euphoria38 1 517 08-31-2026, 10:34 AM
Last Post: Herrema4
  [Tiara Open] Fireboy FE-241 replacement roboh20 0 460 07-25-2026, 09:15 AM
Last Post: roboh20
  Windshield Wiper Arms and Blades Lafobrian@gmail.com 17 16,326 06-20-2026, 11:59 AM
Last Post: nylakeshome
  Freezer Replacement for 40' Tiara Reprise1 4 1,943 06-09-2026, 02:28 PM
Last Post: fuzzy
