Replacement Radar Arch Dome Light?
I'd like to replace/upgrade the Perko dome light in the radar arch of my 2002 3100 Open. Has anyone replaced theirs and have a good LED light to recommend?
The wife would like one that has soft white and blue lighting....I just want something that's bright enough that I can actually see things while at the helm.
Thanks!
These are ones that i used to replace on my 3500 arch. Mine are powder coated white. I got mine about 4-5 yrs ago so they may have changed a little byt they work great. Red/White/Blue all 3 colors in one light. I also put them in my cockpit as well.
(02-05-2018, 06:18 PM)trit21 Wrote: [Only registered and activated users can see links Click here to register]
Fantastic. Thank you. Was it a direct fit or did you have to increase the cutout diameter or drill new holes for the screws? Looks like a great light!
From what I remember I had to open the hole a little with a dremel but don't remember how much. Probably had to drill new mounting holes as well but it was a while ago and I don't exactly remember. Wasn't a big deal otherwise I would have remembered that.
(02-07-2018, 05:33 PM)trit21 Wrote: From what I remember I had to open the hole a little with a dremel but don't remember how much. Probably had to drill new mounting holes as well but it was a while ago and I don't exactly remember. Wasn't a big deal otherwise I would have remembered that.
Thanks!
Lumitec mirage, great lights and some models are Simma Le with standard switch
You could also consider the [Only registered and activated users can see links Click here to register] from NDR, in case you're looking for some high quality alternatives.
Or you could just replace the bulb with a LED bulb. I've done most of mine in the boat and they work great.
Marinebeam.com
  DC Panel Volt/Amp Seclector Switch Replacement Peave 4 1,517 11-07-2025, 02:50 PM
  [Tiara Open] Cabin light bulb replacement Bbarroll 2 2,884 06-06-2025, 03:57 PM
Last Post: Joe.dammann
  [Tiara Open] Push button breaker 12v replacement Mydiamond 2 1,586 09-28-2024, 09:01 AM
  Nav/anchor Light Switch Joeboch348 5 3,036 06-29-2024, 09:55 AM
Last Post: roboh20
  1994 43 Open Cockpit Courtesy Light Fixtures carbon20 1 2,032 11-12-2023, 11:37 AM
Last Post: Afarneti
Replacement Radar Arch Dome Light?00
