Tiara Open Electrical issue house battery draw
#11
P
(04-22-2018, 03:36 PM)rcwiegand Wrote: I have the same issue with a 2004 35 open.  I did zero in on the two in cabin Carbon Monoxide alarms being hard wired and drawing ~2 amps each.  Not certain if this is the final culprit-I disconnected them from power to see.  I will check later this week.  Pls keep me informed and I will do the same.
I identified the two orange wires they are from ECM computor for engines and should always be hot. Please let me know how you make out with Carbon alarms. Thanks
#12
Disconnected Carbon alarms and it resolved most of drain issue. House batteries still drained to 9+ volts after sitting two weeks in dry dock with switch off-this used to be the case in less than 24 hours. I will replace hard wired alarms with new ones with internal batteries-like the smoke alarm. Still need to put a amp meter in series at the battery feed to isolate and determine the remaining drain.
  2006 3600 Sovran Generator Battery location Final Pursuit 0 781 08-09-2025, 07:49 AM
  [Tiara Open] 2005 TIARA 2900 OPEN DC ELECTRICAL SCHEMATIC COPY HIGH SPIRTED 2 2,757 07-05-2025, 12:54 PM
Last Post: HIGH SPIRTED
  1997 4000 express shore power issue Salty0ne 10 4,029 03-31-2025, 08:27 PM
  [Tiara Open] battery isolator waycamp 1 1,187 07-06-2024, 09:02 PM
  Battery charger Location-1994 31 open Rt31 2 2,414 05-30-2023, 11:40 AM
Last Post: Rt31
2 Guest(s)
Electrical issue house battery draw00
