Helm panel light switch de-energiezes the port tachometer
I have a fault I can't source.  When I turn my helm panel light switch on, my port tach goes dead.  When I turn the panel lights off the port tach immediately re-energizes.  I checked the wires for both the tach and the light switch and nothing looks pinched or otherwise compromised.  Is there a relay that might have failed?  Any other ideas?  2003 3500 Open. Thanks
I don't think there is a relay. if you can get a meter on the power leads for the tach I would start there. Or try running a jumper from a good ground source to the tach ground and see if that fixes it. You can do the same on the +12v side if the ground checks out.
(07-13-2018, 09:29 PM)jclark003 Wrote: I don't think there is a relay. if you can get a meter on the power leads for the tach I would start there. Or try running a jumper from a good ground source to the tach ground and see if that fixes it. You can do the same on the +12v side if the ground checks out.
Good suggestions. Despite all of the ground wires looking free of corrosion and like they were making good contact inside the spade, I decided to cut the wires back and put a fresh spade connector on.  There are 4 ground wires that all converge into the single spade that attaches to the tach illumination ground post.  So far after doing that, (1) the panel lights no longer short out the tach, and (2) the tach stopped bouncing.  Maybe there was a internal corrosion or a bad contact inside the spade that was causing the issue.  Hard to believe since everything looked clean.
Dave
[-] The following 1 user Likes ddfour1's post:
Misdirection (07-16-2018)
Doesn't take much. Glad it all worked out.
  DC Panel Volt/Amp Seclector Switch Replacement Peave 4 1,479 11-07-2025, 02:50 PM
  [Tiara Open] Cabin light bulb replacement Bbarroll 2 2,836 06-06-2025, 03:57 PM
Last Post: Joe.dammann
  Main Panel Switch needed or 1997 40 mid cabin express Salty0ne 0 703 03-28-2025, 09:44 PM
Last Post: Salty0ne
  Electric Breaker panel Jbuchsdvm 5 4,757 10-21-2024, 10:08 AM
  Nav/anchor Light Switch Joeboch348 5 3,017 06-29-2024, 09:55 AM
Last Post: roboh20
Helm panel light switch de-energiezes the port tachometer00
