Tiara Open Electrical Issue - HELP
Hey Tiaradom
Need help - guidance for an issue on my 98 31 open.
I have a tricky electrical problem.   The foil face of the mid bulkhead is hot and conducting a full 12+v.  I won't bore any one on how i found this but it is definitely catching a short or ground issues and the entire face is hot when testings with a meter to either engine.
Now I believe that I've isolated the issue to the Port Engine main line.  I've removed the entire line (wrapped bundle from engine to the through hole to the helm) form the bulkhead (straps, zip ties, etc.), so i don't think there is a direct short and must be somewhere else.  I believe that I've also eliminated the charger, by removing the direct feed from the charger to the battery I still have voltage at the foil.  Also eliminated are the only other items on the port  wiring diagram connections the bilge pumps, disconnected and still have voltage.
Any ideas or thoughts?  Anyone else see this sometime?  It may have been this way since I've had the boat, but it's definitely not right.
Thanks in advance!   Bang Head
Try turning off things on the main breaker panel one at a time and see if you can isolate the line or pump etc, that is shorting out.
  [Tiara Open] 2005 TIARA 2900 OPEN DC ELECTRICAL SCHEMATIC COPY HIGH SPIRTED 2 2,872 07-05-2025, 12:54 PM
Last Post: HIGH SPIRTED
  1997 4000 express shore power issue Salty0ne 10 4,355 03-31-2025, 08:27 PM
  Glendinnning cable reel issue OurHighLife 3 2,582 11-05-2022, 09:11 AM
  [Tiara Open] electrical issue dduca@comcast.net 3 3,857 12-12-2021, 04:04 PM
Last Post: Donaldjames
  [Tiara Open] 2004 32 Open DC Electrical Panel fixkr 0 1,689 11-11-2021, 10:22 PM
Last Post: fixkr
11-06-2026 12:51 PM
