Tiara Open 3200 Open Stereo Amp Location
Can anyone tell me where the stereo amplifier (for the cockpit speakers) is located on a 2006 3200 open? It is the factory Clarion system. I have an issue with bad static in the cockpit only that I suspect is related to the amp or an amp ground. Thanks for the help!
Its in the cabin behind the wall forward of the steering station. There's four screws holding a wood partition just above the a.c. unit.
Thank you. Appreciate the help. No I have to decide to tackle now or wait until spring.
Check the condition of the speakers themselves, often high heat and humidity can destroy the material around the cones as it did in most of my clarions. Also I notice when on shore power and using the tuner for local stations theres alot of static but as soon as I unplug from shore it goes away. Had the same issue with other boats.
Thanks for the reply. I did replace the speakers already with JL Audio units and “sometimes” it sounds great but sometimes a lot of static. Static is present even on aux input and even when muted. It seems like a bad ground or amp but I’ll check it out. Appreciate everyone’s input.
Same problem
07 3000. Open
Interested to hear more
Trying to do the same thing on my 3600. I would assume it was in the same spot. Any pictures?
Found the amp forward of the helm in the cabin. I needed to remove the back of one of the banquet seats aft. the back had 2 screws securing it behind the seat cushion. This exposed a panel with 8 screws. The amp was behind the panel mounted to the port side wall.
Thanks everyone. We are in Michigan so won’t be unwrapping the boat for another two weeks. Hopefully will find something obvious when I look. I will post results. Please update with your findings as well. I’m expecting to find a ground or moisture issue or the need to replace the amplifier.
I replaced my exterior speakers, (only have static on them) sound/ static is much better. Next to be changed is corroded speaker wire at connection to speakers, I will post update
  Refrigerator replacement for 1989 Tiara open/express Halekai 1 3,578 03-08-2026, 11:03 PM
Last Post: Longbeach3910
  2008 36 Open with Cummins Dosplays Afarneti 1 4,317 03-04-2026, 05:56 AM
Last Post: ken9090z
  [Tiara Open] 1996 33 open gauges Mydiamond 1 4,596 08-18-2025, 10:57 AM
  [Tiara Open] Loose parallel wire behind ignition plate 1996 Tiara open Mydiamond 0 4,347 08-14-2025, 08:05 PM
  2019 Tiara 34 LX stereo not working Bud Dieselman 0 1,413 06-27-2023, 11:23 AM
Last Post: Bud Dieselman
3200 Open Stereo Amp Location00
