Battery charger
I have a 2003 42 open it has a 50 amp battery charger, do these just die?? Went down in engine room , reads 0 on gauge and no humming noise , I took face plate off and it looks like it may b fried, and fan on top look rusted?? Boat was in saltwater for 16 years now freshwater, has 8 batteries, (4) 500cca that are about 6 years old and (4) 800 cca that were 1 year old , was thinking of getting a bigger amp charger, recommendations would b greatly appreciated, THANK YOU
Checking the charger should be as simple as putting a dvm on each battery bank and observing volts after turning on battery charger (with engine off). You should see about >13.0 vdc when charging and about 12 or so when not charging. If it's a Charles you may want to check the internal fuses. A bad battery can blow the output fuse and I would think a shorted fan could take out the ac line fuse. Here is a link to the manual
http://www.charlesindustries.com/marine_...argers.pdf
No direct experience but I hear Mastervolt and Victron have very good equipment should you need to replace. As for increasing the amperage output from what I know the charge rate should be sized to keep up with the house load. if Tiara put a 50 amp charger in there that is probably enough. That said going higher output won't hurt anything.
  [Tiara Open] C-Charles Charger Series 5000 failed ReelMagic 3 1,044 10-27-2025, 09:51 AM
  Tiara Express Battery Charger Replacement Svdb12@chartermi.net 0 717 09-07-2025, 11:19 AM
  original tiara battery charger drifter 1 826 07-09-2025, 10:22 AM
  2000 Tiara 3500 Express Seven Battery Replacement - Ouch JMGCINCY2023 6 2,416 01-31-2025, 09:02 PM
  Battery Charger issue 04' 32 open Coastie57 2 1,308 04-24-2024, 08:41 AM
Last Post: Matta0413
