38 tiara open electronics issue
Can someone please assistant me with voltage gauges they don’t read anything, but boat is running fine. I have had problems in the past month with the oil gauges. We did do the manual gauges and now the oil pressure is fine according to the manual gauges.  Why don’t I have a reading on my voltage gauges? Any help would be great.
First step is the check the pins on the back of the gauge with a voltmeter. Just pull the dash back to access. the volt gauges are easy. The wires at the top are for the backlighting, the two on the bottom are positive and negative. If you have voltage on the back then the gauges are bust, otherwise you need to keep tracing the wires back to find the problem. Many times its a grounding problem.
Hi
Wally man is on point. I was having similar issues and it turned out to be the ground wires. clipped added the female end and works great now
  2019 Tiara 34 LX stereo not working Bud Dieselman 1 1,650 10-01-2026, 07:47 PM
Last Post: icloud
  Refrigerator replacement for 1989 Tiara open/express Halekai 1 4,296 03-08-2026, 11:03 PM
Last Post: Longbeach3910
  2008 36 Open with Cummins Dosplays Afarneti 1 5,000 03-04-2026, 05:56 AM
Last Post: ken9090z
  [Tiara Open] 1996 33 open gauges Mydiamond 1 5,354 08-18-2025, 10:57 AM
  [Tiara Open] Loose parallel wire behind ignition plate 1996 Tiara open Mydiamond 0 5,023 08-14-2025, 08:05 PM
38 tiara open electronics issue00
