Threads: 5
I am looking for the black bolt covers under the swim ladder and hatches in my 2007 3000 open.
Any ideas of who makes them?
Scott
Threads: 30
Are you talking of the plastic end caps that fit over the bolts so you don't cut yourself on the protruding ends? I do not know who makes them, but you should be able to get them from any fastener supply company. Graybar, Ace Sunshine, and any other company that sells fasteners.
Let us know where you source them when you find them.
Threads: 30
You could also just buy stainless cap nuts to screw over the ends of the bolts. Make sure you use Loctite when you install them or they will eventually vibrate off if you go this route.
Threads: 0
Home Port: Boca Raton, FL
Vessel Info: 2001
3500 Open
Cummins 6bta 370
The ladder on my boat (2001 35 Open) came from Windline (Calf.). I have received parts from them in the past . They do a nice job.
Good luck.
Threads: 3
Home Port: SWFlorida
Vessel Info: 2008 35 Tiara Sorvan with diesels
Found a cap that fit over the bolt end in hardware department of lowes
