Waste and Water indicators not working
Hello,
I have a 2001 Tiara 3100 and the waste and water sensors on the main panel in the cabin are longer working.  They always show zero. Any ideas?
Thanks in advance.
I had similar issues with the gauge always reading zero. I pulled the waste tank sensor, cleaned it and replaced... Still didn't read correctly. Checked all connections which were fine.. Out of desperation I tapped the gauge while holding the switch down. It worked and the gauge showed the waste tank level... Need to understand that the sensor in the tank doesn't go all the way to the bottom. It only goes down 8" which leaves 4" below the sensor that isn't read by the gauge... My tank is 12" deep and the sensor only goes down 8"... BTW same with the fresh water reading.. Sensor goes down within 4" of the bottom so the last 4" isn't shown by the gauge either...M2C
I have a 2006 Sovran 36 and had a similar issue. My system was made by Fireboy. Fireboy has discontinued their waste and water sensor products. They did have inventory of both sensors last summer. I bought 2 sets to make sure I had backups. If yours is Fireboy I would contact them to see if they have your sensors still.
John
36 Sovran, Cummins QSC
  [Tiara Convertible] How do I repair a broken wash down/city water connection plate? Peave 4 1,285 05-12-2026, 10:18 AM
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,532 02-23-2026, 11:01 AM
  Water alarm in the diesel filters maxcav 0 405 02-15-2026, 05:34 AM
Last Post: maxcav
  Water if forward bilge after rain lenoah 0 507 11-21-2025, 05:53 PM
Last Post: lenoah
  3500 Exp. engine hatch not working. giff1 1 810 11-17-2025, 09:56 AM
Waste and Water indicators not working00
