4100 Open Gray Water Tank
The primary pump on my gray water tank quit running.  I've verified that the float switch in the bottom of the tank is in the on position but that's all the diagnosis I've done, I'll try and direct connect the pump to a 12v battery tomorrow  Anyone else have to repair/replace this pump?  I'd like to exhaust all possibilities before spending $300 plus on the replacement.
(07-13-2020, 08:07 PM)tglass Wrote: The primary pump on my gray water tank quit running.  I've verified that the float switch in the bottom of the tank is in the on position but that's all the diagnosis I've done, I'll try and direct connect the pump to a 12v battery tomorrow  Anyone else have to repair/replace this pump?  I'd like to exhaust all possibilities before spending $300 plus on the replacement.
After draining the tank I found that a wire on the float switch was broken.
  [Tiara Open] Cockpit Fresh and Sea Water Connectors Bob's Boat 1 663 06-20-2026, 07:16 AM
  1997 4000 Express - Holding Tank Replacement jennyJ 9 4,473 05-26-2026, 07:27 AM
Last Post: frank.koetter
  Water tank level sensors Final Pursuit 4 2,112 10-09-2025, 06:37 AM
  2006 3600 Sovran -AC water hoses Final Pursuit 1 1,062 09-17-2025, 05:52 AM
Last Post: Splendor
  Water quick connect fittings Final Pursuit 2 1,503 07-30-2025, 03:18 PM
4100 Open Gray Water Tank00
