Tiara Sovran Replacing courtesy lights in cabin steps
Hi,
Does anyone have any suggestions about replacing the festoon bulb in the steps.  There is barely enough slack in the wires to pull the light out and it would appear the lense/frame are one piece.  I tried to get one out an broke the bulb and wonder how to get the new one in without breaking that as well.
Thanks!
I removed the original fixture in the steps and replaced them with LED fixtures purchased from West Marine. Easy project, less heat and less amperage used/needed. Also replaced all halogen bulbs in cabin and cockpit with LED's purchased on Amazon-same result; less heat and amperage.
I have a 2006 36 Sovran. The original fixtures were made by Imtra. One of my fixtures was damaged so I had to replace the entire unit. The replacement is https://www.imtra.com/03da5a9d-cc0c-4623...detail.htm
The bulbs can also be replaced with LED. Here is where I got them. https://m4products.com/wedge-based-led-lights/
John
36 Sovran, Cummins QSC
Definitely change them out to led. Better light, less amps drawn (a lot less) and you will never have to mess with them again. At least not for about 10,000 hours.
Oh and when you do make sure to leave more wire length to help out the next guy.
(03-08-2020, 11:16 AM)mjcoffin@hotmail.com Wrote: Hi,
Thanks!
what year is your boat ?
i did this on the 01 38 open...... changed every single bulb on the boat to LED.  light are prob made by https://www.cantalupilighting.it   also check out IMTRA  super easy get proper gauge wires and DIY. make sure you use good connectors and heat shrink tubing
Capt. Brett M. Sause
USCG Master Licensed Captain
443.220.4339
www.themarineminute.com
I know its a silly question but how do you get to the bulb in these fixtures? It doesn't appear the cover spins and I tried to pry one and the staineless steel ring came off of the fixture. Am I missing something? I swear I can change a light bulb but the one in the headliner of the cabin in my 4500 is really fighting me. It is the first bulb I have needed to replace the previous owner left me some halogen bulbs to do it, but I can't get to the bulb.
I have the same question about almost all the lights. How do you get the trim rings off without breaking them or damaging whatever the fixtures are mounted to? Most look like they just twist off, but don’t seem to. The ones over the galley and under the cabinets to starboard just twist off, but I can’t figure out the ones mounted on the front of the stairs, onto the headliner or in the cockpit. The light fixture with the plunger switch under the top stair also needs replacing.
On my 36 Sovran the covers on lights on the front of the stairs pull off. They are held on with tension. The fixtures were made by Imtra. Unfortunately they are no longer available. They do have a sealed LED replacement
John
(08-19-2020, 06:05 PM)Dlaporte58 Wrote: I have the same question about almost all the lights. How do you get the trim rings off without breaking them or damaging whatever the fixtures are mounted to? Most look like they just twist off, but don’t seem to. The ones over the galley and under the cabinets to starboard just twist off, but I can’t figure out the ones mounted on the front of the stairs, onto the headliner or in the cockpit. The light fixture with the plunger switch under the top stair also needs replacing.
What lights are you specifically talking about
Thanks John. I will try to gently pry the trim rings off the stair lights. I was afraid to damage the fiberglass behind them.
To answer the question from bsause, I'd like to eventually replace all the lamps with led's, in addition to the ones on the front of the stairs, those include the round courtesy lights on the headliner, the reading lights behind the berth and the courtesy lights inside the hardtop in the cockpit.
  Interior ceiling lights gdynkowski 0 370 08-08-2026, 12:29 PM
Last Post: gdynkowski
  cabin lights honest mark 2 1,937 04-05-2026, 10:25 AM
  Navigation Lights Jarrod 2 1,619 04-03-2026, 08:25 PM
  Replacing fuel full hose 3100 Open Joeboch348 1 1,083 08-20-2025, 03:53 PM
Last Post: S4Survivor
  Cupholder blue lights and ottomans Shaken53 1 1,044 08-18-2025, 10:39 AM
Last Post: Sapphire
