06-07-2021, 08:08 AM
06-07-2021, 08:20 AM
I believe you need ILW2x4 mini bulbs. I purchased them (not cheap) from Atlantic Marine Lighting but have seen them on Amazon in packs of 10...
06-07-2021, 09:29 AM
06-08-2021, 07:45 AM
I have a 2006 36 Sovran. I have replaced the bulbs in all my courtesy lights bulbs on the deck with blue LEDs from Superbrightleds.com I am not sure what the bulb number is. The cover of the fixture pulls off and the bulb pushes in. There should be a number on the bulb. I had to replace one of the fixtures in the steps in the cabin. IMTRA does not make fixture with a replaceable bulb any more. They are sealed LEDs. I think it is part BCM3416K-40-4 but I would check dimensions to make sure. Good Luck
06-09-2021, 02:33 PM
(This post was last modified: 06-09-2021, 02:34 PM by Euphoria38.)
(06-08-2021, 07:45 AM)jhhall Wrote: I have a 2006 36 Sovran. I have replaced the bulbs in all my courtesy lights bulbs on the deck with blue LEDs from Superbrightleds.com I am not sure what the bulb number is. The cover of the fixture pulls off and the bulb pushes in. There should be a number on the bulb. I had to replace one of the fixtures in the steps in the cabin. IMTRA does not make fixture with a replaceable bulb any more. They are sealed LEDs. I think it is part BCM3416K-40-4 but I would check dimensions to make sure. Good Luck
Thanks John
I love the 36 Sorvan model you have. Great boat with awesome power for its size.
| DC Panel Volt/Amp Seclector Switch Replacement | Peave | 4 | 1,432 |
11-07-2025, 02:50 PM Last Post: hiccup |
| [Tiara Open] Cabin light bulb replacement | Bbarroll | 2 | 2,771 |
06-06-2025, 03:57 PM Last Post: Joe.dammann |
| [Tiara Open] Push button breaker 12v replacement | Mydiamond | 2 | 1,509 |
09-28-2024, 09:01 AM Last Post: Mydiamond |
| 2000 3500 Express Cockpit Fridge and Plug Outlet Breaker Location | JMGCINCY2023 | 2 | 1,563 |
08-18-2024, 07:22 PM Last Post: JMGCINCY2023 |
| LED Lighting Upgrade 3100 Open | TWO SUNS | 2 | 6,551 |
07-11-2024, 02:07 AM Last Post: Pop Alexandra |
| 1 Guest(s) |
