Transom Door
When prepping our 3200 open for winterization I noticed the transom door was rubbing on the transom when shutting.  I do have some seams on the door that are popping most likely to water and expanding the aluminum.  Has anyone successfully repaired this? what would be the process?
Not aware of any aluminum on or near the transom door on my 32. Have you checked the hinge screws for tightness? If that doesn't work it's possible to remove one or both hinges and slightly bend them to bring the door closer to the hinge side.
(11-24-2021, 07:46 AM)reeltimebrad Wrote: Not aware of any aluminum on or near the transom door on my 32. Have you checked the hinge screws for tightness? If that doesn't work it's possible to remove one or both hinges and slightly bend them to bring the door closer to the hinge side.
See attached photo
Thumbnail(s)
Looks like saltwater must have gotten through to the backing plate. You'll need to find a good fiberglass shop and have the plate removed and remade from 316 stainless. Should be a relatively simple job since it's easy to remove the door and bring it to someone.
Inserting a 316 plate is unnecessary and not ideal. Your core has gotten water. Do a full fiberglass repair after removing the hardware. Any good fiberglass person can do it and ensure there is no water getting in in the future. If you want to go nuts, embed a plate of G10 instead of the core where the hinges attach.
There is a aluminum plate that the hinges are threaded into that is corroding and swelling up that's why it's cracking. Get rid of the aluminum and get it sealed up.
You will have to remove all the corrosion using the necessary tools, and apply a new layer of paint on it. This how my dad was always doing, he had a workshop where he was repairing boats, and as a regular guest, I've seen how different problems were solved, I still keep them in my mind. I don't like to repair boats, I only like riding them, so when I am going on vacation, I usually take a [Only registered and activated users can see links Click here to register] with my entire family, and spend the time with pleasure.
  bathroom door handle fuzzy 2 410 07-18-2026, 05:43 PM
Last Post: fuzzy
  [Tiara Open] Access cover to sliding door on 43 open MariTime2 0 841 12-14-2025, 05:34 PM
Last Post: MariTime2
  Transom Door/Gate Repair MC1600 4 4,186 08-25-2025, 10:53 PM
Last Post: Splendor
  1990 3100 open - can I add a transom door? 604.jim.smith@gmail.com 0 553 05-27-2025, 04:49 PM
  Sliding Door Locks and Handle MarkM 2 1,080 04-28-2025, 09:41 PM
Last Post: jmk
Transom Door00
