Fiamm trumpet horn compressor location
I have a 2013 31’ Tiara Open and the trumpet horn on the hardtop sounds like a sick duck. I am looking to replace it, but I don’t see where the small compressor is located. I have emailed Tiara, but have not heard back from them. I’m not sure if it’s in the hardtop itself, but I don’t want to remove upholstery if I don’t have to. My plan is to replace it with a 12 volt electric horn in lieu of the compressor.
Any information is much appreciated,
It’s behind the Starboard speaker cover just above the fridge/wetbar behind the helm.
FYI - My horn had the same problem and it was due to the air line to the horn being slightly kinked at the connection to the horn.
Good luck!
Hold on.... The terrible sound you hear may not be the fault of the compressor.... I also have the same horns on my 38 Open and found the problem to be with the plastic diaphragms inside the horns themselves.... Take out the 3 screws holding the top of the horns on and you should see the diaphragms.... Clean or replace them and clean/smooth the top lip of the diaphragm seat.... The diaphragms aren't seating correctly.... Have to do this procedure every several years and seems to always fix thee horns.. M2C
I ordered new kits from Zoro.com. Measure the diameter of the removable covers on top of the horns. I eyeballed the size first and ordered the 2.5". I really need the 3". They sent me the three inch and said to keep the 2.5". They were cheap.
Flamm Horn Replacement Kits
2.5 “Zoro # G7469905
3.0” Zoro  # G7469948
Thank you all for replies, I actually tried to remove the 3 screws at each horn, but apparently the previous owner tried as well, and stripped the heads of 4 of the 6 screws!
Exclamation [Tiara Sovran] Sunroof motor location on ‘13 sovran 45? Tiara45 0 458 07-28-2026, 06:28 AM
Last Post: Tiara45
  [Tiara Open] GFCI Location HIGH SPIRTED 0 544 07-11-2025, 11:16 AM
Last Post: HIGH SPIRTED
  Horn stanfarbman 1 1,132 07-08-2025, 10:31 AM
Last Post: peakay
  C39 Horn Replacement - location of the Compressor? fishtiara17 3 1,337 02-26-2025, 10:14 PM
Last Post: Napercpl
  2000 3500 Express Cockpit Fridge and Plug Outlet Breaker Location JMGCINCY2023 5 2,488 08-19-2024, 07:22 PM
Today 11:36 AM
Yesterday 05:08 PM
