Threads: 1
Home Port: Ohio River -- Louisville
Vessel Info: 1999 Tiara 3500 Express with Cummins 6BTA5.9-M3s
Having problems with the sliding plexiglass door to the cabin sticking on my 1999 3500 Express. Can be very difficult to slide open, particularly from the inside. Any ideas on how to fix? Thanks!
Threads: 46
Remove door and replace trucks which once you remove and identify the size of trucks, can be found on line or from Tiara
Threads: 14
11
Home Port: Kings Park, NY
I had a similar problem on my 2003 38 Open and solved it by cleaning the lower and upper tracks... The roller trucks were OK... Fist took a compressor and blew out lots of dirt, etc. Once cleaned I sprayed the tracks/rollers as best as I could with silicon spray. Worked for me and its been several years since I did it. M2C
