Tiara Open diesel in bilge
A couple of months ago I had a water sensor in the racor that went bad and was replaced.  the leak seemingly was coming from there.  Any advice on why that loosened to cause a leak??  Better yet, how can I be sure it won't happen again?  I did not do the work and am no mechanic.  32 Open Cummins
If there is one thing I have learned, everything on a boat is broken. You just don't know it yet.
How old is the boat? I have never had an issue with a racor before. Could it have been damaged while changing a filter? Maybe someone accidentally bumped it while working in the bilge?
2008, yes the filters changed and a water sensor replaced on that side. I think it just vibrated loose? could that happen?
It should not be able to vibrate loose. Did it start leaking and then get changed or was it leaking prior to the change?
so what happened was the water in fuel sensor went bad so I had that changed and both racors changed at the same time. After that, unfortunately I did not have any idea because I wasn't at the boat for a while it was several months later that we found out the diesel in the bilge problem. Now, we did have some really cold weather (for Orange Beach) where temps got in low 20's one night but heat was on in cabin and boat is in the water. I don't know what cold weather could do to a fuel system if any? I've cleaned bilge thoroughly and let boat sit for 2-3 weeks and now there is another very small sheen on bilge water? she is a 2008 and very well kept so I wouldn't think fuel tank (hopefully).
  Water alarm in the diesel filters maxcav 0 519 02-15-2026, 05:34 AM
Last Post: maxcav
  Water if forward bilge after rain lenoah 0 630 11-21-2025, 05:53 PM
Last Post: lenoah
  Keel bilge pump runs on 52 Sovran Salon during trips Knot On Call 9 2,951 08-21-2025, 08:28 PM
  [Tiara Sovran] Sea Strainers on 2009 Volvo Diesel Engine Donaldjames 3 3,638 04-10-2025, 08:23 PM
Last Post: Donaldjames
  43 open keel bilge vs mid bilge bnr@dur-a-flex.com 2 1,563 12-08-2024, 07:34 AM
Last Post: bnr@dur-a-flex.com
