Steering issues with engine down
Twice this season, I lost my port engine and both times attempted to limp back to my slip. When engaging starboard engine in forward and turning wheel to starboard, the bow goes to port even with increased throttle. When turning the wheel to port, the bow goes to port, the way it should.
When engaging starboard engine in reverse and turning wheel, the boat turns the way it should.
Any suggestions? I’m perplexed!
What you're describing is 100% normal for a twin-screw inboard boat. If you go nearly hard over on the wheel to starboard with only the starboard engine in gear, you should be able to maintain a straight course. Your ability to actually turn to starboard will be greatly reduced though. As an example, for my boat when there's only a single engine in gear, I need to maintain the rudders at about 70% hard over towards the engine in gear just to maintain a straight course.
This is because the starboard propeller is off center and therefore pushes the boat to the port, and vice-versa. This is why twin-screws are so easy to maneuver with just the gear selectors and can spin on a dime.
The bow still goes to port even with rudder turned hard starboard.
It may be something specific with that model--rudders may too small. But I'd check to make sure the rudders are making full and equal travel in both directions. Can you steer straight with just the port engine in gear? Is there an autopilot fitted? If so, what rudder angle can be achieved in each direction?
  [Tiara Open] Unknown noise from Tiara 3800 Open engine room Tony Saitta 2 460 10-05-2026, 11:57 AM
  [Tiara Sovran] Main engine hatch gas shock lift assist bracket separation hmtrerice 0 382 08-21-2026, 02:33 PM
Last Post: hmtrerice
  3500 Exp. engine hatch not working. giff1 1 963 11-17-2025, 09:56 AM
  [Tiara Open] 2900 engine mounts North000 0 677 06-06-2025, 03:47 PM
Last Post: North000
  [Tiara Sovran] Sea Strainers on 2009 Volvo Diesel Engine Donaldjames 3 3,633 04-10-2025, 08:23 PM
Last Post: Donaldjames
Today 01:18 PM
Today 01:17 PM
10-30-2026 06:10 PM
